Formal specification and prototyping of a program specializer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1995
This paper reports on the use of formal specifications in the development of a software maintenance tool for specializing imperative programs, which have become very complex due to extensive modifications. The tool is specified in terms of inference rules and operates by induction on the abstract syntax. The correctness of these rules is proved using rule induction. A Prolog prototype has been derived for Fortran programs, using the Centaur programming environment.
fulltext.pdf (786.22 Ko) Télécharger le fichier
inria-00165933 , version 1 (30-07-2007)
Sandrine Blazy, Philippe Facon. Formal specification and prototyping of a program specializer. TAPSOFT '95: Theory and Practice of Software Development, 6th International Joint Conference CAAP/FASE, May 1995, Aarhus, Denmark. pp.666-680, ⟨10.1007/3-540-59293-8_227⟩. ⟨inria-00165933⟩
Collections
CNAM CEDRIC-CNAM
30 Consultations
113 Téléchargements
