Estimating Average End-to-End Delays in IEEE 802.11 Multihop Wireless Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present a new analytic model for evaluating average end-to-end delay in IEEE 802.11 multihop wireless networks. Our model gives closed expressions for the end-to-end delay in function of arrivals and service time patterns. Each node is modeled as a M/M/1/K queue from which we can derive expressions for service time via queueing theory. By combining this delay evaluation with different admission controls, we design a protocol called DEAN (Delay Estimation in Ad hoc Networks). DEAN is able to provide delay guarantees for QoS applications in function of the application level requirements. Through extensive simulations, we compare performance evaluation of DEAN with other approaches like, for instance, DDA.
RR-dean.pdf (636.13 Ko) Télécharger le fichier
inria-00166017 , version 1 (31-07-2007)
  • HAL Id : inria-00166017 , version 1
Cheikh Sarr, Isabelle Guérin-Lassous. Estimating Average End-to-End Delays in IEEE 802.11 Multihop Wireless Networks. [Research Report] RR-6259, INRIA. 2007, pp.24. ⟨inria-00166017⟩
150 Consultations
1159 Téléchargements
