The mpFq library and implementing curve-based key exchanges - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We present a library for finite field arithmetic. The originality of this library lies in the fact that specialized code is automatically produced for the selected finite fields. The opportunity of compile-time optimizations yields substantial performance improvements compared to libraries which initialize the finite field at runtime. This library is used to present benchmarks on some curve-based public key cryptosystems.
mpfq.pdf (183.18 Ko) Télécharger le fichier
inria-00168429 , version 1 (28-08-2007)
  • HAL Id : inria-00168429 , version 1
Pierrick Gaudry, Emmanuel Thomé. The mpFq library and implementing curve-based key exchanges. SPEED: Software Performance Enhancement for Encryption and Decryption, ECRYPT Network of Excellence in Cryptology, Jun 2007, Amsterdam, Netherlands. pp.49-64. ⟨inria-00168429⟩
399 Consultations
455 Téléchargements
