Botnets for scalable management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
With an increasing number of devices that must be managed, the scalability of network and service management is a real challenge. A similar challenge seems to be solved by botnets which are the major security threats in today's Internet where a botmaster can control several thousands of computers around the world. This is done although many hindernesses like firewalls, intrusion detection systems and other deployed security appliances to protect current networks. From a technical point of view, such an efficiency can be a benefit for network and service management. This paper describes a new management middleware based on botnets, evaluates its performances and shows its potential impact based on a parametric analytical model.
dsom.pdf (249.99 Ko) Télécharger le fichier
presdsom.pdf (1.11 Mo) Télécharger le fichier
Format : Autre
inria-00170425 , version 1 (26-09-2008)
  • HAL Id : inria-00170425 , version 1
Jérôme François, Radu State, Olivier Festor. Botnets for scalable management. 18th IFIP/IEEE International Workshop on Distributed Systems: Operations and Management (DSOM'07, MANWEEK'07), Oct 2007, San José, United States. ⟨inria-00170425⟩
104 Consultations
134 Téléchargements
