Interest Point Detection with Wavelet Maxima Lines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2007
In this paper, we propose a new approach in image processing for interest point detection. Thanks to the link between linear scale-space and wavelet decompositions, we are able to build a structure in scale-space based on wavelet maxima lines. This framework allows robust detection of objects (or blob-like structures) present in the image, and the computation of their characteristic scale. Eventually the estimation of their shape can be performed. Keywords: scale-space representation, maxima lines of wavelet decomposition, blob detection, scale selection.
InterestPointDetectionWithWaveletMaximaLines.pdf (276.71 Ko) Télécharger le fichier
inria-00171678 , version 1 (12-09-2007)
  • HAL Id : inria-00171678 , version 1
Christophe Damerval, Sylvain Meignen. Interest Point Detection with Wavelet Maxima Lines. 2007. ⟨inria-00171678⟩
163 Consultations
410 Téléchargements
