HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Biological model of motion integration and segmentation based on form cues
Émilien Tlapale 1, * Guillaume Masson 2 Pierre Kornprobst 1
* Corresponding author
1 ODYSSEE - Computer and biological vision
DI-ENS - Département d'informatique - ENS Paris, CRISAM - Inria Sophia Antipolis - Méditerranée , ENS-PSL - École normale supérieure - Paris, Inria Paris-Rocquencourt, ENPC - École des Ponts ParisTech
Abstract : Active vision is an essential part of every biological organism possessing an eye system: posture, eye movements, visual research, ... All require a motion percept to operate. At the basis of active vision lays the ability to calculate movements of objects in the scene, at least on a sufficient level to react correctly. In this report we present a model of motion integration and segmentation in the first visual cortex areas. Specifically we modeled the first two cortex areas involved in motion processing in the primate: V1 and MT. To be able to process motion correctly a visual system also need to deal with form information. We investigate how form cues coming from the ventral pathway can be used by the V1/MT dorsal pathway to solve some perception problems. By using a recurrent dynamical system between the V1 and MT layers we are able to find out psychophysical results such as motion integration and center-surround effects due to the feedback connections, or end-of-line and 2D features detectors thanks to the shunting inhibition. We propose to modulate this system by a form information coming from the ventral stream and are thus able to explain asymmetric center-surround effects as well as motion segmentation and segregation between extrinsic and intrinsic junctions.
Document type :
Reports
Complete list of metadata
Cited literature [46 references]  Display  Hide  Download
https://hal.inria.fr/inria-00172412
Contributor : Émilien Tlapale Connect in order to contact the contributor
Submitted on : Monday, September 17, 2007 - 1:37:03 PM
Last modification on : Thursday, March 17, 2022 - 10:08:31 AM
Long-term archiving on: : Friday, November 25, 2016 - 6:51:44 PM
File
RR-6293.pdf
Identifiers
  • HAL Id : inria-00172412, version 2
Citation
Émilien Tlapale, Guillaume Masson, Pierre Kornprobst. Biological model of motion integration and segmentation based on form cues. [Research Report] RR-6293, INRIA. 2007, pp.44. ⟨inria-00172412v2⟩
Share
Metrics
Record views
178
Files downloads
107
