HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
comparison-based algorithms are robust and randomized algorithms are anytime.
Sylvain Gelly 1 Sylvie Ruette 2 Olivier Teytaud 1
1 TANC - Algorithmic number theory for cryptology
Inria Saclay - Ile de France, LIX - Laboratoire d'informatique de l'École polytechnique [Palaiseau]
Abstract : Randomized search heuristics (e.g., evolutionary algorithms, simulated annealing etc.) are very appealing to practitioners, they are easy to implement and usually provide good performance. The theoretical analysis of these algorithms usually focuses on convergence rates. This paper presents a mathematical study of randomized search heuristicswhich use comparison based selectionmechanism. The twomain results are: (i) comparison-based algorithms are the best algorithms for some robustness criteria, (ii) introducing randomness in the choice of offspring improves the anytime behavior of the algorithm. An original Estimation of Distribution Algorithm combining (i) and (ii) is proposed and successfully experimented.
Document type :
Journal articles
Complete list of metadata
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/inria-00173221
Contributor : Olivier Teytaud Connect in order to contact the contributor
Submitted on : Wednesday, September 19, 2007 - 2:14:50 PM
Last modification on : Friday, February 4, 2022 - 3:15:43 AM
Long-term archiving on: : Friday, April 9, 2010 - 2:28:54 AM
File
lb2.pdf
Identifiers
  • HAL Id : inria-00173221, version 1
Citation
Sylvain Gelly, Sylvie Ruette, Olivier Teytaud. comparison-based algorithms are robust and randomized algorithms are anytime.. Evolutionary Computation, Massachusetts Institute of Technology Press (MIT Press), 2007. ⟨inria-00173221⟩
Share
Metrics
Record views
216
Files downloads
187
