Anytime many-armed bandits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This paper introduces the many-armed bandit problem (ManAB), where the number of arms is large comparatively to the relevant number of time steps. While the ManAB framework is relevant to many real-world applications, the state of the art does not offer anytime algorithms handling ManAB problems. Both theory and practice suggest that two problem categories must be distinguished; the easy category includes those problems where good arms have reward probability close to 1; the difficult category includes other problems. Two algorithms termed FAILURE and MUCBT are proposed for the ManAB framework. FAILURE and its variants extend the non-anytime approach proposed for the denumerable-armed bandit and non-asymptotic bounds are shown; it works very efficiently for easy ManAB problems. Meanwhile, MUCBT efficiently deals with difficult ManAB problems.
mabcap2.pdf (972.9 Ko) Télécharger le fichier
inria-00173263 , version 1 (19-09-2007)
  • HAL Id : inria-00173263 , version 1
Olivier Teytaud, Sylvain Gelly, Michèle Sebag. Anytime many-armed bandits. CAP07, 2007, Grenoble, France. ⟨inria-00173263⟩
303 Consultations
393 Téléchargements
