Shape and Reflectance Recovery using Multiple Images with Known Illumination Conditions - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 2007
(1) , (1) , (1) , (1) , (1)
1
We develop a variational method to recover both the shape and the reflectance of a scene surface(s) using multiple images, assuming that illumination conditions are fixed and known in advance. Scene and image formation are modeled with known information about cameras and illuminants, and scene recovery is achieved by minimizing a global cost functional with respect to both shape and reflectance. Unlike most previous methods recovering only the shape of Lambertian surfaces, the proposed method considers general dichromatic surfaces. We verify the method using synthetic data sets containing specular reflection.
RR-6309.pdf (2.07 Mo) Télécharger le fichier
Dates and versions
inria-00175274 , version 1 (27-09-2007)
inria-00175274 , version 2 (27-09-2007)
Identifiers
  • HAL Id : inria-00175274 , version 2
Cite
Kuk-Jin Yoon, Emmanuel Prados, Peter Sturm, Amael Delaunoy, Pau Gargallo. Shape and Reflectance Recovery using Multiple Images with Known Illumination Conditions. [Research Report] RR-6309, INRIA. 2007, pp.31. ⟨inria-00175274v2⟩
236 View
174 Download
Share
