Reports
The ECMWF System 3 ocean analysis
Magdalena Balmaseda 1 Arthur Vidard 2 David Anderson 1
2 MOISE - Modelling, Observations, Identification for Environmental Sciences
Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology, LJK - Laboratoire Jean Kuntzmann, Inria Grenoble - Rhône-Alpes
Abstract : A new operational ocean analysis system (system 3 or S3) has been implemented at ECMWF. It consists of two analysis streams: (i) a historical reanalysis from 01/01/1959 which is continuously maintained up to 11 days behind real time and is used to initialize seasonal forecasts, and (ii) an early delivery ocean analysis, produced daily in real time, used to initialize the monthly forecasts. The S3 ocean analysis has several innovative features, including an on-line bias correction algorithm, the assimilation of salinity data on T-surfaces and assimilation of altimeter-derived sea level anomalies and global trends. The new S3 ocean analysis system outperforms the previous operational system (S2) in the tropics; the biases in both temperature and salinity are reduced, and the representation of the interannual variability is improved. In the extratropics S3 has larger interannual and decadal variability than S2, since the relaxation to climatology has been reduced, but the biases are larger. It is shown that data assimilation has a large impact on the mean state of the first guess, and consistently re- duces the bias. In the tropics, the interannual variability is improved, especially the ENSO related variability. In the extratropics, the variability is increased. Data assimilation has a favourable impact on the skill of seasonal forecasts of SST, especially in the western Pacific, where the forecast skill in terms of RMS error is improved at all lead times. In the first 3 months, the forecast skill of the coupled model is improved by more than 20% by using data assimilation in the initialization of the ocean. The S3 ocean analysis is a synthesis of available ocean observations, and provides a record of the history of the ocean. It is continued in real time and provides a valuable tool for climate analysis.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00176165
Contributor : Arthur Vidard Connect in order to contact the contributor
Submitted on : Tuesday, October 2, 2007 - 5:01:18 PM
Last modification on : Thursday, January 20, 2022 - 5:30:19 PM
Identifiers
  • HAL Id : inria-00176165, version 1
Collections
Citation
Magdalena Balmaseda, Arthur Vidard, David Anderson. The ECMWF System 3 ocean analysis. [Research Report] Technical Memorandum, ECMWF, number 508., 2007, pp.47. ⟨inria-00176165⟩
Share
Metrics
Record views
165
