Second order sliding mode control of underactuacted mechanical systems II: Orbital stabilization of an inverted pendulum with application to swing up / balancing control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2008
Orbital stabilization of an underactuated cart-pendulum system is under study. The quasihomogeneous control synthesis is utilized to design a second order sliding mode controller that drives the actuated cart to a periodic reference orbit in finite time, while the non-actuated pendulum produces bounded oscillations. A modified Van der Pol oscillator is introduced into the synthesis as an asymptotic generator of the periodic motion. The resulting closed-loop system is capable of moving from one orbit to another by simply changing the parameters of the Van der Pol modification. Performance issues of the proposed synthesis are illustrated in numerical and experimental studies of the swing up/balancing control problem of moving a pendulum, located on an actuated cart, from its stable downward position to the unstable inverted position and stabilizing it about the vertical.
IJRNC07_Part2.pdf (400.12 Ko) Télécharger le fichier
inria-00179858 , version 1 (16-10-2007)
Raul Santiesteban, Thierry Floquet, Yuri Orlov, Samer Riachy, Jean-Pierre Richard. Second order sliding mode control of underactuacted mechanical systems II: Orbital stabilization of an inverted pendulum with application to swing up / balancing control. International Journal of Robust and Nonlinear Control, 2008, 18 (4-5), pp.544-556. ⟨10.1002/rnc.1203⟩. ⟨inria-00179858⟩
273 Consultations
894 Téléchargements
