Mapping sequences by parts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Algorithms for Molecular Biology Année : 2007
We present the N-map method, a pairwise and asymmetrical approach which allows us to compare sequences by taking into account evolutionary events that produce shuffled, reversed or repeated elements. Basically, the optimal N-map of a sequence s over a sequence t is the best way of partitioning the first sequence into N parts and placing them, possibly complementary reversed, over the second sequence in order to maximize the sum of their gapless alignment scores.
inria-00180004 , version 1 (17-10-2007)
Gilles Didier, Carito Guziolowski. Mapping sequences by parts. Algorithms for Molecular Biology, 2007, 2, pp.11. ⟨10.1186/1748-7188-2-11⟩. ⟨inria-00180004⟩
70 Consultations
0 Téléchargements
