A New Challenge for Compression Algorithms: Genetic Sequences
Universal data compression algorithms fail to compress genetic sequences. It is due to the specificity of this particular kind of "text". We analyze in some details the properties of the sequences, which cause the failure of classical algorithms. We then present a lossless algorithm, biocompress-2, to compress the information contained in DNA and RNA sequences, based on the detection of regularities, such as the presence of palindromes. The algorithm combines substitutional and statistical...
Bio-informatique [q-bio.QM]
grumbach.pdf (207.19 Ko)
Télécharger le fichier
biocompress/.DS_Store (6 Ko)
biocompress/Biocompress (64 Ko)
biocompress/Biocompress-2 (100.26 Ko)
biocompress/Biocompress.c (12.54 Ko)
biocompress/Biocompress2.c (16.4 Ko)
biocompress/Makefile-Biocompress (406 B)
biocompress/Makefile-Biocompress-2 (823 B)
biocompress/ReadMe (488 B)
biocompress/allocb2.c (633 B)
biocompress/arith-2-memetable.c (38.99 Ko)
biocompress/autn.c (4.58 Ko)
biocompress/auton3 (56 Ko)
biocompress/bitio.c (5.13 Ko)
biocompress/bitio.h (1.47 Ko)
biocompress/codeb3.c (1.03 Ko)
biocompress/encode13.c (15.72 Ko)
biocompress/errhand.c (648 B)
biocompress/errhand.h (334 B)
biocompress/main-c.c (4.48 Ko)
biocompress/main-e.c (2.91 Ko)
biocompress/main.h (532 B)
biocompress/typeb2.h (755 B)
Origine | Fichiers produits par l'(les) auteur(s) |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
Format | Autre |
