Hierarchies of probabilistic models of space for mobile robots: the bayesian map and the abstraction operator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
This paper presents a new method for probabilistic modelling of space, called the Bayesian Map for- malism. It offers a generalization of some com- mon approaches found in the literature, as it does not constrain the dependency structure of the prob- abilistic model. The formalism allows incremental building of hierarchies of models, by the use of the Abstraction Operator. In the resulting hierarchy, lo- calization in the high level model is based on prob- abilistic competition of the lower level models. Ex- perimental results validate the concept, and hint at its usefulness for large scale scenarios.
Autre [cs.OH]
diard03b.pdf (214.91 Ko) Télécharger le fichier
inria-00182081 , version 1 (24-10-2007)
  • HAL Id : inria-00182081 , version 1
Julien Diard, Pierre Bessiere, Emmanuel Mazer. Hierarchies of probabilistic models of space for mobile robots: the bayesian map and the abstraction operator. Proc. of the Workshop on Reasoning with Uncertainty in Robotics, Aug 2003, Acapulco (MX), France. ⟨inria-00182081⟩
123 Consultations
436 Téléchargements
