Anxiety in Mice: A Principal Component Analysis Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Neural plasticity Année : 2007
Two principal component analyses of anxiety were undertaken investigating two strains of mice (ABP/Le and C57BL/6ByJ) in two different experiments, both classical tests for assessing anxiety in rodents. The elevated plus-maze and staircase were used for the first experiment, and a free exploratory paradigm and light-dark discrimination were used for the second. The components in the analyses produced definitions of four fundamental behavior patterns: novelty-induced anxiety, general activity, exploratory behavior, and decision making. We also noted that the anxious phenotype was determined by both strain and experimental procedure. The relationship between behavior patterns and the use of specific tests plus links with the genetic background are discussed.
inria-00186107 , version 1 (07-11-2007)
Yan Clément, Chantal Joubert, Caroline Kopp, Eve M. Lepicard, Patrice Venault, et al.. Anxiety in Mice: A Principal Component Analysis Study. Neural plasticity, 2007, ⟨10.1155/2007/35457⟩. ⟨inria-00186107⟩
206 Consultations
0 Téléchargements
