HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Spectral Clustering en IRM de diffusion pour Retrouver les Faisceaux de la Matière Blanche
Demian Wassermann 1, * Maxime Descoteaux 1 Rachid Deriche 1
* Corresponding author
1 ODYSSEE - Computer and biological vision
DI-ENS - Département d'informatique - ENS Paris, CRISAM - Inria Sophia Antipolis - Méditerranée , ENS-PSL - École normale supérieure - Paris, Inria Paris-Rocquencourt, ENPC - École des Ponts ParisTech
Abstract : White matter fiber clustering allows to get insight about anatomical structures in order to generate atlases, perform clear visualizations and compute statistics across subjects, all important and current neuroimaging problems. In this work, we present a Diffusion Maps clustering method applied to diffusion MRI in order to cluster and segment complex white matter fiber bundles. It is well-known that Diffusion Tensor Imaging (DTI) is restricted in complex fiber regions with crossings and this is why recent High Angular Resolution Diffusion Imaging (HARDI) such has Q-Ball Imaging (QBI) have been introduced to overcome these limitations. QBI reconstructs the diffusion orientation distribution function (ODF), a spherical function that has its maxima agreeing with the underlying fiber populations. In this paper, we introduce the usage of the Diffusion Maps technique and show how it can be used to directly cluster set of fiber tracts, that could be obtained through a streamline tractography for instance, and how it can also help in segmenting fields of ODF images, obtained through a linear and regularized ODF estimation algorithm based on a spherical harmonics representation of the Q-Ball data. We first show the advantage of using Diffusion Maps clustering over classical methods such as N-Cuts and Laplacian Eigenmaps in both cases. In particular, our Diffusion Maps requires a smaller number of hypothesis from the input data, reduces the number of artifacts in fiber tract clustering and ODF image segmentation and automatically exhibits the number of clusters in both cases by using an adaptive scale-space parameter. We also show that our ODF Diffusion Maps clustering can reproduce published results using the diffusion tensor (DT) clustering with N-Cuts on simple synthetic images without crossings. On more complex data with crossings, we show that our ODF-based method succeeds to separate fiber bundles and crossing regions whereas the DT-based methods generate artifacts and exhibit wrong number of clusters. Finally, we illustrate the potential of our approach on a real brain dataset where we successfully segment well-known fiber bundles.
Complete list of metadata
Cited literature [51 references]  Display  Hide  Download
https://hal.inria.fr/inria-00186861
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, November 13, 2007 - 3:06:54 PM
Last modification on : Thursday, March 17, 2022 - 10:08:32 AM
Long-term archiving on: : Friday, November 25, 2016 - 6:34:38 PM
RR-6351.pdf
Identifiers
  • HAL Id : inria-00186861, version 2
Collections
Citation
Demian Wassermann, Maxime Descoteaux, Rachid Deriche. Spectral Clustering en IRM de diffusion pour Retrouver les Faisceaux de la Matière Blanche. [Research Report] RR-6351, INRIA. 2007, pp.52. ⟨inria-00186861v2⟩
Share
Metrics
Record views
348
Files downloads
152
