Spectral Geometry Processing with Manifold Harmonics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2007
Bruno Vallet
Bruno Lévy
We present a new method to convert the geometry of a mesh into frequency space. The eigenfunctions of the Laplace-Beltrami operator are used to define Fourier-like function basis and transform. Since this generalizes the classical Spherical Harmonics to arbitrary manifolds, the basis functions will be called Manifold Harmonics. It is well known that the eigenvectors of the discrete Laplacian define such a function basis. However, important theoretical and practical problems hinder us from using this idea directly. From the theoretical point of view, the combinatorial graph Laplacian does not take the geometry into account. The discrete Laplacian (cotan weights) does not have this limitation, but its eigenvectors are not orthogonal. From the practical point of view, computing even just a few eigenvectors is currently impossible for meshes with more than a few thousand vertices. In this paper, we address both issues. On the theoretical side, we show how the FEM (Finite Element Modeling) formulation defines a function basis which is both geometry-aware and orthogonal. On the practical side, we propose a band-by-band spectrum computation algorithm and an out-of-core implementation that can compute thousands of eigenvectors for meshes with up to a million vertices. Finally, we demonstrate some applications of our method to interactive convolution geometry filtering and interactive shading design.
ManifoldHarmonics.pdf (1.8 Mo) Télécharger le fichier
inria-00186931 , version 1 (13-11-2007)
  • HAL Id : inria-00186931 , version 1
Bruno Vallet, Bruno Lévy. Spectral Geometry Processing with Manifold Harmonics. [Technical Report] 2007. ⟨inria-00186931⟩
1032 Consultations
2275 Téléchargements
