Quantitative comparisons of forward problems in MEEG. - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 2007
(1, 2) , (1) , (2) , (1)
1
2
Maureen Clerc
  • Function : Author
  • PersonId : 843531
Mariette Yvinec
Théodore Papadopoulo
This document gives comparisons between several methods that solve the forward problem in MEEG by comparing their precision on a 3-layer spherical model. These methods are based on finite elements which either use surfacic meshes with triangles, volumic meshes with tetrahedra, or implicit elements deduced from levelsets.
RR-6364.pdf (2.14 Mo) Télécharger le fichier
Dates and versions
inria-00189515 , version 1 (21-11-2007)
inria-00189515 , version 2 (22-11-2007)
inria-00189515 , version 3 (09-01-2010)
Identifiers
  • HAL Id : inria-00189515 , version 3
Cite
Emmanuel Olivi, Maureen Clerc, Mariette Yvinec, Théodore Papadopoulo. Quantitative comparisons of forward problems in MEEG.. [Rapport de recherche] RR-6364, INRIA. 2007, pp.32. ⟨inria-00189515v3⟩
267 View
329 Download
Share
