On-Line Domain Knowledge Management for Case-Based Medical Recommendation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Domain knowledge may be used in a medical application to avoid wrong decisions, e.g., decisions raising contraindications. The contribution of this paper is twofold. First, it presents an approach for exploiting domain knowledge in a case-based decision support system in the domain of oncology. This approach is based on the so-called conservative adaptation that provides a solution necessarily consistent with the domain knowledge. Second, this paper describes an approach for the evolution of this domain knowledge when the expert rejects a proposed solution as being inconsistent with his/her knowledge. This inconsistency is characteristic of a difference between the domain knowledge of the system and the expert knowledge; from an interactive analysis, a piece of knowledge to be added to the domain knowledge is pointed out. This approach to domain knowledge evolution is implemented in a prototype called FrakaS.
cordier-fuchs-lieber-mille-WS-CBR-Health-ICCBR07.pdf (139.45 Ko) Télécharger le fichier
inria-00189782 , version 1 (22-11-2007)
  • HAL Id : inria-00189782 , version 1
Amélie Cordier, Béatrice Fuchs, Jean Lieber, Alain Mille. On-Line Domain Knowledge Management for Case-Based Medical Recommendation. 5th workshop on CBR in the Health Sciences, a workshop of the seventh International Conference on Case-Based Reasoning (ICCBR-07), D. C. Wilson and D. Khemani (volume editors), I. Bichindaritz and S. Montani, Aug 2007, Belfast, United Kingdom. pp.285--294. ⟨inria-00189782⟩
211 Consultations
200 Téléchargements
