Abstract : This report describes the different technologies used par the manufacturers of autostereoscopic displays which are also called 3D displays. It also presents some existing 3D displays as well as the problems of resampling inherent in this kind of display. Next, it introduces more particularly the NEWSIGHT 3D displays as well as the interleaving of 8 views used by this kind of 3D display. The implementation of this interleaving on the CPU and on the GPU (programmable graphic cards) is also described.
https://hal.inria.fr/inria-00192688 Contributor : Anne JaiguConnect in order to contact the contributor Submitted on : Thursday, November 29, 2007 - 11:16:09 AM Last modification on : Friday, February 4, 2022 - 4:06:55 AM Long-term archiving on: : Monday, April 12, 2010 - 5:29:55 AM
