Templates, Microformats and Structured Editing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Vincent Quint
  • Fonction : Auteur
  • PersonId : 833612
Irène Vatton
  • Fonction : Auteur
  • PersonId : 833611
Microformats and semantic XHTML add semantics to web pages while taking advantage of the existing (X)HTML infrastructure. This approach enables new applications that can be deployed smoothly on the web. But there is currently no way to describe rigorously this type of markup and authors of web pages have very little help for creating and encoding semantic markup. A language that addresses these issues is presented in this paper. Its role is to specify semantically rich XML languages in terms of other XML languages, such as XHTML. The language is versatile enough to represent templates that can capture the overall structure of large documents as well as the fine details of a microformat. It is supported by an editing tool for producing documents encoded in a semantically rich markup language, still fully compatible with XHTML.
DocEng2006.pdf (142.94 Ko) Télécharger le fichier
inria-00193958 , version 1 (05-12-2007)
Francesc Campoy Flores, Vincent Quint, Irène Vatton. Templates, Microformats and Structured Editing. ACM Symposium on Document Engineering, Oct 2006, Amsterdam, Netherlands. pp.188-197, ⟨10.1145/1166160.1166211⟩. ⟨inria-00193958⟩
Collections
INRIA INRIA2
307 Consultations
617 Téléchargements
