Generation properties of Maurer-Cartan invariants - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2007
Evelyne Hubert
For the action of a Lie group, which can be given by its infinitesimal generators only, we characterize a generating set of differential invariants of bounded cardinality and show how to rewrite any other differential invariants in terms of them. Those invariants carry geometrical significance and have been used in equivalence problem in differential geometry.
gpmci.pdf (251.71 Ko) Télécharger le fichier
inria-00194528 , version 1 (06-12-2007)
inria-00194528 , version 2 (10-12-2007)
  • HAL Id : inria-00194528 , version 1
Evelyne Hubert. Generation properties of Maurer-Cartan invariants. 2007. ⟨inria-00194528v1⟩
232 Consultations
766 Téléchargements
