A Feature Based Navigation System for an Autonomous Underwater Robot
We present a system for autonomous underwater navigation as implemented on a Nekton Ranger autonomous underwater vehicle, AUV. This is one of the first implementations of a practical application for simultaneous localization and mapping on an AUV. Besides being an application of real-time SLAM, the implemtation demonstrates a novel data fusion solution where data from 7 sources are fused at different time scales in 5 separate estimators. By modularizing the data fusion problem in this way each estimator can be tuned separately to provide output useful to the end goal of localizing the AUV, on an a priori map. The Ranger AUV is equipped with a BlueView blazed array sonar which is used to detect features in the underwater environment. Underwater testing results are presented. The features in these tests are deployed radar reflectors.
Robotique [cs.RO]
