Reports
Towards Persistence-Based Reconstruction in Euclidean Spaces
Frédéric Chazal 1 Steve Oudot 1, *
* Corresponding author
1 GEOMETRICA - Geometric computing
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : Manifold reconstruction has been extensively studied for the last decade or so, especially in two and three dimensions. Recently, significant improvements were made in higher dimensions, leading to new methods to reconstruct large classes of compact subsets of Euclidean space $\R^d$. However, the complexities of these methods scale up exponentially with d, which makes them impractical in medium or high dimensions, even for handling low-dimensional submanifolds. In this paper, we introduce a novel approach that stands in-between classical reconstruction and topological estimation, and whose complexity scales up with the intrinsic dimension of the data. Specifically, when the data points are sufficiently densely sampled from a smooth $m$-submanifold of $\R^d$, our method retrieves the homology of the submanifold in time at most $c(m)n^5$, where $n$ is the size of the input and $c(m)$ is a constant depending solely on $m$. It can also provably well handle a wide range of compact subsets of $\R^d$, though with worse complexities. Along the way to proving the correctness of our algorithm, we obtain new results on \v Cech, Rips, and witness complex filtrations in Euclidean spaces.
Complete list of metadatas
Cited literature [37 references]  Display  Hide  Download
https://hal.inria.fr/inria-00197543
Contributor : Rapport de Recherche Inria <>
Submitted on : Tuesday, December 18, 2007 - 11:20:08 AM
Last modification on : Friday, February 23, 2018 - 2:20:08 PM
Document(s) archivé(s) le : Thursday, September 23, 2010 - 4:58:06 PM
RR-6391.pdf
Identifiers
  • HAL Id : inria-00197543, version 3
  • ARXIV : 0712.2638
Collections
Citation
Frédéric Chazal, Steve Oudot. Towards Persistence-Based Reconstruction in Euclidean Spaces. [Research Report] RR-6391, INRIA. 2008. ⟨inria-00197543v3⟩
Share
Metrics
Record views
645
Files downloads
358
