Convergence of a semi-Lagrangian scheme for the reduced Vlasov-Maxwell system for laser-plasma interaction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
The subject matter of this paper concerns the numerical approximation of reduced Vlasov-Maxwell models by semi-Lagrangian schemes. Such reduced systems have been introduced recently in the literature for studying the laser-plasma interaction. We recall the main existence and uniqueness results on these topics, we present the semi-Lagrangian scheme and finally we establish the convergence of this scheme.
bostan_crouseilles.pdf (1.18 Mo) Télécharger le fichier
inria-00221359 , version 1 (28-01-2008)
inria-00221359 , version 2 (18-02-2008)
inria-00221359 , version 3 (18-02-2008)
  • HAL Id : inria-00221359 , version 1
Mihai Bostan, Nicolas Crouseilles. Convergence of a semi-Lagrangian scheme for the reduced Vlasov-Maxwell system for laser-plasma interaction. [Research Report] 2008. ⟨inria-00221359v1⟩
207 Consultations
361 Téléchargements
