Nonlinear V6 schemes for compressible flow
We describe several numerical schemes for conservation laws well adapted to nonlinear aerodynamics. The schemes are vertex centered, dissipative. They apply with second-order accuracy to unstructured tetrahedrizations and extend to higher order (up to sixth) on a certain type of Cartesian triangulations/tetrahedrizations.
