A FastSLAM algorithm based on the Unscented Filtering with adaptive selective resampling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
A FastSLAM approach to the SLAM problem is considered in this paper. An improvement to the classical FastSLAM algorithm has been obtained by replacing the Extended Kalman Filters used in the prediction step and in the feature update with Unscented Kalman Filters and by introducing an adaptive selective resampling. The simulations confirm the effectiveness of the proposed modifications.
fsr_39.pdf (281.18 Ko) Télécharger le fichier
inria-00258750 , version 1 (25-02-2008)
  • HAL Id : inria-00258750 , version 1
Manuel Cugliari, Francesco Martinelli. A FastSLAM algorithm based on the Unscented Filtering with adaptive selective resampling. 6th International Conference on Field and Service Robotics - FSR 2007, Jul 2007, Chamonix, France. ⟨inria-00258750⟩
Collections
FSR2007
84 Consultations
387 Téléchargements
