On the code revers engineering problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
Mathieu Cluzeau
  • Fonction : Auteur
  • PersonId : 847426
Jean-Pierre Tillich
This article deals with the problem of quantifying how many noisy codewords have to be eavesdropped in order to reverse engineer a code. The main result of this paper is a lower bound on this quantity and the proof that this number is logarithmic in the length for LDPC codes.
CluzeauTillich.pdf (79.25 Ko) Télécharger le fichier
inria-00261471 , version 1 (07-03-2008)
  • HAL Id : inria-00261471 , version 1
Mathieu Cluzeau, Jean-Pierre Tillich. On the code revers engineering problem. 2008. ⟨inria-00261471⟩
Collections
INRIA INRIA2
50 Consultations
201 Téléchargements
