A Queueing System for Modeling a File Sharing Principle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Florian Simatos
  • Fonction : Auteur
  • PersonId : 841874
Philippe Robert
We investigate in this paper the performance of a simple file sharing principle. For this purpose, we consider a system composed of N peers becoming active at exponential random times; the system is initiated with only one server offering the desired file and the other peers after becoming active try to download it. Once the file has been downloaded by a peer, this one immediately becomes a server. To investigate the transient behavior of this file sharing system, we study the instant when the system shifts from a congested state where all servers available are saturated by incoming demands to a state where a growing number of servers are idle. In spite of its apparent simplicity, this queueing model (with a random number of servers) turns out to be quite difficult to analyze. A formulation in terms of an urn and ball model is proposed and corresponding scaling results are derived. These asymptotic results are then compared against simulations.
full.pdf (260.17 Ko) Télécharger le fichier
inria-00262405 , version 1 (11-03-2008)
inria-00262405 , version 2 (11-03-2008)
  • HAL Id : inria-00262405 , version 1
Florian Simatos, Philippe Robert, Fabrice Guillemin. A Queueing System for Modeling a File Sharing Principle. ACM Sigmetrics, Jun 2008, Annapolis, United States. ⟨inria-00262405v1⟩
78 Consultations
305 Téléchargements
