A classification of invasive patterns in AOP - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Aspect-Oriented Programming (AOP) improves modularity by encapsulating crosscutting concerns into aspects. Some mechanisms to compose aspects allow invasiveness as a mean to integrate concerns. Invasiveness means that AOP languages have unrestricted access to program properties. Such kind of languages are interesting because they allow performing complex operations and better introduce functionalities. In this report we present a classification of invasive patterns in AOP. This classification characterizes the aspects invasive behavior and allows developers to abstract about the aspect incidence over the program they crosscut.
report.pdf (151.36 Ko) Télécharger le fichier
inria-00266555 , version 1 (10-04-2008)
inria-00266555 , version 2 (10-04-2008)
inria-00266555 , version 3 (24-04-2008)
  • HAL Id : inria-00266555 , version 1
  • ARXIV : 0804.1696
Freddy Munoz, Benoit Baudry, Olivier Barais. A classification of invasive patterns in AOP. [Research Report] 2008. ⟨inria-00266555v1⟩
178 Consultations
297 Téléchargements
