A viscoelastic model for avascular tumor growth - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Didier Bresch
  • Fonction : Auteur
  • PersonId : 836391
Thierry Colin
  • Fonction : Auteur
  • PersonId : 836679
  • IdRef : 069826188
Benjamin Ribba
  • Fonction : Auteur
  • PersonId : 845354
In this article, we present a continuous model for tumor growth . This model describes the evolution of three cellular densities: the density of sane tissue, cancer cells and extracellular medium. In order to render correctly the cellular division, this model use a discrete description of the cell cycle (the set of steps a cell has to undergo in order to divide) presented in [7]. To render cellular adhesion and the mechanics which may influence the growth, we use a viscoelastic approach. This model extends the one presented in [7] with a more realistic description of the movement.
paper.pdf (221.15 Ko) Télécharger le fichier
inria-00267292 , version 1 (27-03-2008)
inria-00267292 , version 2 (21-04-2008)
inria-00267292 , version 3 (01-09-2008)
inria-00267292 , version 4 (10-07-2009)
  • HAL Id : inria-00267292 , version 3
Didier Bresch, Thierry Colin, Emmanuel Grenier, Benjamin Ribba, Olivier Saut. A viscoelastic model for avascular tumor growth. [Research Report] 2008. ⟨inria-00267292v3⟩
602 Consultations
559 Téléchargements
