A Design Methodology for Weakly-Hard Real-Time Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Daniel Simon
Olivier Sename
The problem of the integrated control and weakly-hard real-time scheduling is addressed. F irst, an abstract model of control tasks execution is introduced, allowing the establishme nt of a formal relationship linking control performance to deadline misses. Then, the noti on of accelerable control task is introduced. An accelerable control task has the property that more executions are performed, better is the control performance. Thanks to this lat ter property, it becomes straightforward to design the control laws according to the avera ge execution times of control tasks, and guaranteeing that in the worst-case scenario, the minimal allowable performance will be achieved. Based on Bellman optimality principle, su fficient conditions for a given control task to be accelerable are stated. A design method of optimal control laws for the weakly-hard execution model is then proposed.
Automatique
acctasks.pdf (178.69 Ko) Télécharger le fichier
inria-00269209 , version 1 (02-04-2008)
  • HAL Id : inria-00269209 , version 1
Mohamed El Mongi Ben Gaïd, Daniel Simon, Olivier Sename. A Design Methodology for Weakly-Hard Real-Time Control. IFAC WC 2008 - 17th IFAC World Congress, IFAC, Jul 2008, Séoul, South Korea. pp.7. ⟨inria-00269209⟩
375 Consultations
299 Téléchargements
