Scalable Distributed Video-on-Demand: Theoretical Bounds and Practical Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We analyze a distributed system where n nodes called boxes store a large set of videos and collaborate to serve simultaneously n videos or less. We explore under which conditions such a system can be scalable while serving any sequence of demands. We model this problem through a combination of two algorithms: a video allocation algorithm and a connection scheduling algorithm. The latter plays against an adversary that incrementally proposes video requests.
podc-rr.pdf (351.8 Ko) Télécharger le fichier
inria-00270406 , version 1 (04-04-2008)
inria-00270406 , version 2 (08-04-2008)
  • HAL Id : inria-00270406 , version 1
  • ARXIV : 0804.0743
Laurent Viennot, Yacine Boufkhad, Fabien Mathieu, Fabien de Montgolfier, Diego Perino. Scalable Distributed Video-on-Demand: Theoretical Bounds and Practical Algorithms. [Research Report] 2008, pp.19. ⟨inria-00270406v1⟩
Collections
LIAFA
175 Consultations
140 Téléchargements
