A distributed algorithm for computing and updating the process number of a forest - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
In this paper, we present a distributed algorithm to compute various parameters of a tree such as the process number, the edge search number or the node search number and so the pathwidth. This algorithm requires n steps, an overall computation time of O(n log(n)), and n messages of size log_3(n)+3. We then propose a distributed algorithm to update the process number (or the node search number, or the edge search number) of each component of a forest after adding or deleting an edge. This second algorithm requires O(D) steps, an overall computation time of O(D log(n)), and O(D) messages of size log_3(n)+3, where D is the diameter of the modified connected component. Finally, we show how to extend our algorithms to trees and forests of unknown size using messages of less than 2a+4+e bits, where a is the parameter to be determined and e=1 for updates algorithms.
disc.pdf (163.92 Ko) Télécharger le fichier
inria-00288304 , version 1 (16-06-2008)
inria-00288304 , version 2 (18-06-2008)
inria-00288304 , version 3 (27-06-2008)
  • HAL Id : inria-00288304 , version 3
  • ARXIV : 0806.2710
David Coudert, Florian Huc, Dorian Mazauric. A distributed algorithm for computing and updating the process number of a forest. [Research Report] RR-6560, INRIA. 2008. ⟨inria-00288304v3⟩
424 Consultations
682 Téléchargements
