Reports
Improvement of Reduced Order Modeling based on Proper Orthogonal Decomposition
Michel Bergmann 1, 2, * Charles-Henri Bruneau 1, 2 Angelo Iollo 1, 2
* Corresponding author
2 MC2 - Modélisation, contrôle et calcul
Inria Bordeaux - Sud-Ouest, UB - Université de Bordeaux, CNRS - Centre National de la Recherche Scientifique : UMR5251
Abstract : This report focuses on improving the stability as well as the approximation properties of Reduced Order Models (ROM) based on Proper Orthogonal Decomposition (POD). The ROM is obtained by seeking a solution belonging to the POD subspace and that at the same time minimizes the Navier-Stokes residuals. We propose a modified ROM that directly incorporates the pressure term in the model. The ROM is then stabilized making use of a method based on the fine scale equations. An improvement of the POD solution subspace is performed thanks to an hybrid method that couples direct numerical simulations and reduced order model simulations. The methods proposed are tested on the two-dimensional confined square cylinder wake flow in laminar regime.
Complete list of metadata
Cited literature [48 references]  Display  Hide  Download
https://hal.inria.fr/inria-00288415
Contributor : Michel Bergmann Connect in order to contact the contributor
Submitted on : Wednesday, June 18, 2008 - 10:39:21 AM
Last modification on : Wednesday, February 2, 2022 - 3:53:25 PM
Long-term archiving on: : Tuesday, September 21, 2010 - 5:11:35 PM
RR_improve.pdf
Identifiers
  • HAL Id : inria-00288415, version 2
Collections
Citation
Michel Bergmann, Charles-Henri Bruneau, Angelo Iollo. Improvement of Reduced Order Modeling based on Proper Orthogonal Decomposition. [Research Report] RR-6561, INRIA. 2008, pp.37. ⟨inria-00288415v2⟩
Share
Metrics
Record views
273
Files downloads
137
