Dynamics and bifurcations of the adaptive exponential integrate-and-fire model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Recently, several two-dimensional spiking neuron models have been introduced, with the aim of reproducing the diversity of electrophysiological features displayed by real neurons while keeping a simple model, for simulation and analysis purposes. Among these models, the adaptive integrate-and-fire model is physiologically relevant in that its parameters can be easily related to physiological quantities. The interaction of the differential equations with the reset results in a rich and complex dynamical structure. We relate the subthreshold features of the model to the dynamical properties of the differential system and the spike patterns to the properties of a Poincaré map defined by the sequence of spikes. We find a complex bifurcation structure which has a direct interpretation in terms of spike trains. For some parameter values, spike patterns are chaotic.
RRTouboulBrette.pdf (1.4 Mo) Télécharger le fichier
inria-00288734 , version 1 (18-06-2008)
inria-00288734 , version 2 (19-06-2008)
inria-00288734 , version 3 (19-06-2008)
inria-00288734 , version 4 (02-07-2008)
  • HAL Id : inria-00288734 , version 2
Jonathan Touboul, Romain Brette. Dynamics and bifurcations of the adaptive exponential integrate-and-fire model. [Research Report] RR-6563, 2008. ⟨inria-00288734v2⟩
380 Consultations
1306 Téléchargements
