Formalizing Projective Plane Geometry in Coq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We investigate how projective plane geometry can be formalized in a proof assistant such as Coq. Such a formalization increases the reliability of textbook proofs whose details and particular cases are often overlooked and left to the reader as exercises. Projective plane geometry is described through two different axiom systems which are formally proved equivalent. Usual properties such as decidability of equality of points (and lines) are then proved in a constructive way. The duality principle as well as formal models of projective plane geometry are then studied and implemented in Coq.
ADG08-postproc-final.pdf (241.2 Ko) Télécharger le fichier
inria-00305998 , version 1 (25-07-2008)
inria-00305998 , version 2 (18-12-2009)
inria-00305998 , version 3 (28-06-2010)
Nicolas Magaud, Julien Narboux, Pascal Schreck. Formalizing Projective Plane Geometry in Coq. Post-proceedings of Automated Deduction in Geometry (ADG) 2008, Thomas Sturm, Sep 2008, Shanghai, China. pp.141-162, ⟨10.1007/978-3-642-21046-4⟩. ⟨inria-00305998v3⟩
142 Consultations
819 Téléchargements
