Schema-Guided Induction of Monadic Queries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The induction of monadic node selecting queries from partially annotated XML-trees is a key task in Web information extraction. We show how to integrate schema guidance into an RPNI-based learning algorithm, in which monadic queries are represented by pruning node selecting tree transducers. We present experimental results on schema guidance by the DTD of HTML.
0.pdf (208.64 Ko) Télécharger le fichier
inria-00309408 , version 1 (06-08-2008)
inria-00309408 , version 2 (26-06-2009)
Jérôme Champavère, Rémi Gilleron, Aurélien Lemay, Joachim Niehren. Schema-Guided Induction of Monadic Queries. 9th International Colloquium on Grammatical Inference, Sep 2008, Saint-Malo, France. pp.15-28, ⟨10.1007/978-3-540-88009-7_2⟩. ⟨inria-00309408v2⟩
159 Consultations
265 Téléchargements
