Zenon: an Extensible Automated Theorem Prover Producing Checkable Proofs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We present Zenon, an automated theorem prover for first order classical logic (with equality), based on the tableau method. Zenon is intended to be the dedicated prover of the Focal environment, an object-oriented algebraic specification and proof system, which is able to produce OCaml code for execution and Coq code for certification. Zenon can directly generate Coq proofs (proof scripts or proof terms), which can be reinserted in the Coq specifications produced by Focal. Zenon can also be extended, which makes specific (and possibly local) automation possible in Focal.
bonichon-delahaye-doligez-lpar-2007.pdf (362.61 Ko) Télécharger le fichier
inria-00315920 , version 1 (01-09-2008)
Richard Bonichon, David Delahaye, Damien Doligez. Zenon: an Extensible Automated Theorem Prover Producing Checkable Proofs. LPAR 2007 - 14th International Conference on Logic for Programming, Artificial Intelligence, and Reasoning, Oct 2007, Yerevan, Armenia. pp.151-165, ⟨10.1007/978-3-540-75560-9_13⟩. ⟨inria-00315920⟩
481 Consultations
364 Téléchargements
