SOFA: A modular yet efficient simulation framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
SOFA is a new open source framework primarily targeted at medical simulation research and industry. It is based on a scene graph data structure extended to physical models and abstract algorithms. Additionally, multiple models of the same objects can easily be used to optimize different tasks such as force computation, collision handling, and rendering. This results in a highly flexible architecture able to model and animate a wide range of simulated objects. We explain the main concepts of SOFA and detail an example of application to a surgery procedure.
sofa-surgetica07.pdf (454.29 Ko) Télécharger le fichier
inria-00319407 , version 1 (09-09-2008)
inria-00319407 , version 2 (15-07-2010)
  • HAL Id : inria-00319407 , version 1
François Faure, Jérémie Allard, Stéphane Cotin, Paul Neumann, Pierre-Jean Bensoussan, et al.. SOFA: A modular yet efficient simulation framework. Surgetica 2007: Computer-Aided Medical Interventions: tools and applications, 2007, Chambery, France. ⟨inria-00319407v1⟩
1012 Consultations
472 Téléchargements
