Self-organizing mixture models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Neurocomputing Année : 2005
Jakob Verbeek
Nikos Vlassis
  • Fonction : Auteur
  • PersonId : 853678
We present an expectation-maximization (EM) algorithm that yields topology preserving maps of data based on probabilistic mixture models. Our approach is applicable to any mixture model for which we have a normal EM algorithm. Compared to other mixture model approaches to self-organizing maps (SOMs), the function our algorithm maximizes has a clear interpretation: it sums data log-likelihood and a penalty term that enforces self-organization. Our approach allows principled handling of missing data and learning of mixtures of SOMs. We present example applications illustrating our approach for continuous, discrete, and mixed discrete and continuous data.
verbeek03neuro_final.pdf (859.02 Ko) Télécharger le fichier
Format : Figure, Image
inria-00321479 , version 1 (16-02-2011)
Jakob Verbeek, Nikos Vlassis, Ben Krose. Self-organizing mixture models. Neurocomputing, 2005, 63, pp.99--123. ⟨10.1016/j.neucom.2004.04.008⟩. ⟨inria-00321479⟩
185 Consultations
1155 Téléchargements
