EMACOP : Environnement Multimédia pour l'Acquisition et la gestion de COrpus Parole
This paper presents an Multimedia Environment for Acquiring and Managing Speech Corpora, running under Windows 95 and windows NT. It provides graphical interface functions to process the signal in order to compute acoustical parameters used in speech analysis, recognition and synthesis. Entries' extraction from main database is also provided from other sources. The new way of programming through the Microsoft COM (Component Object Model), which gives encapsulation/aggregation mechanisms and independence for each module, is used to increase reliability, flexibility and maintainability.
