Modeling Subject-Specific Formant Transition Patterns in /aSa/ Sequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Careful observation reveals that the formant transition patterns in a particular VCV sequence vary according to subjects. It is the case in /aSa/ uttered by French speakers. This variation can be explained by the realization of acoustically equivalent but differently articulated /S/ or /a/ segments and their combination. This paper reports an acoustic simulation experiment aiming at replicating this phenomenon. The results are compared to simultaneous ultrasound tongue contour data and discussed in the perspective of speech inversion.
Toda_Maeda_Aron_Berger.pdf (209.84 Ko) Télécharger le fichier
inria-00326295 , version 1 (16-01-2009)
  • HAL Id : inria-00326295 , version 1
Martine Toda, Shinji Maeda, Michael Aron, Marie-Odile Berger. Modeling Subject-Specific Formant Transition Patterns in /aSa/ Sequences. 8th International Seminar On Speech Production - ISSP'08, Dec 2008, Strasbourg, France. pp.357-360. ⟨inria-00326295⟩
100 Consultations
71 Téléchargements
