BioMAJ: a flexible framework for databanks synchronization and processing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bioinformatics Année : 2008
Large- and medium-scale computational molecular biology projects require accurate bioinformatics software and numerous heterogeneous biological databanks, which are distributed around the world. BioMAJ provides a flexible, robust, fully automated environment for managing such massive amounts of data. The JAVA application enables automation of the data update cycle process and supervision of the locally mirrored data repository. We have developed workflows that handle some of the most commonly used bioinformatics databases. A set of scripts is also available for post-synchronization data treatment consisting of indexation or format conversion (for NCBI blast, SRS, EMBOSS, GCG, etc.). BioMAJ can be easily extended by personal homemade processing scripts. Source history can be kept via html reports containing statements of locally managed databanks. AVAILABILITY: http://biomaj.genouest.org. BioMAJ is free open software. It is freely available under the CECILL version 2 license.
2008Filangi1823_1.pdf (76.99 Ko) Télécharger le fichier
inria-00327502 , version 1 (31-05-2020)
Olivier Filangi, Yoann Beausse, Anthony Assi, Ludovic Legrand, Jean-Marc Larré, et al.. BioMAJ: a flexible framework for databanks synchronization and processing. Bioinformatics, 2008, 24 (16), pp.1823-1825. ⟨10.1093/bioinformatics/btn325⟩. ⟨inria-00327502⟩
185 Consultations
129 Téléchargements
