GEO EXPORTER : a tools to automate publishing of microarray data to Gene Expression Omnibus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
current solutions do not allow automatic publication of microarray experiment results from a microarray data management system to one of the public repositories (Gene Expression Omnibus, ArrayExpress). The end-user is generally involved in various steps of the process which results in low productivity. We have developed a software which allows validating, extraction and automatic publication of microarray data stored in BASE (BioArray Software Environment), a wildly used open source microarray data management system, to Gene Expression Omnibus a reference microarray data repository. The code written in PHP is especially modularized to allow a quick adaptation to any microarray data management system which could be access by SQL.
Fichier non déposé
inria-00329898 , version 1 (13-10-2008)
  • HAL Id : inria-00329898 , version 1
  • PRODINRA : 250385
François Moreews. GEO EXPORTER : a tools to automate publishing of microarray data to Gene Expression Omnibus. ISMB 2008, The International Society for Computational Biology, Jul 2008, Toronto, Canada. ⟨inria-00329898⟩
73 Consultations
0 Téléchargements
