New interface
Preprints, Working Papers, ...
Occupancy Schemes Associated to Yule Processes
Abstract : An occupancy problem with an infinite number of bins and a random probability vector for the locations of the balls is considered. The respective sizes of bins are related to the split times of a Yule process. The asymptotic behavior of the landscape of first empty bins, i.e., the set of corresponding indices represented by point processes, is analyzed and convergences in distribution to mixed Poisson processes are established. Additionally, the influence of the random environment, the random probability vector, is analyzed. It is represented by two main components: an i.i.d.\ sequence and a fixed random variable. Each of these components has a specific impact on the qualitative behavior of the stochastic model. It is shown in particular that for some values of the parameters, some rare events, which are identified, play an important role on average values of the number of empty bins in some regions.
Document type :
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/inria-00331511
Contributor : Philippe Robert Connect in order to contact the contributor
Submitted on : Friday, October 17, 2008 - 9:19:05 AM
Last modification on : Friday, January 21, 2022 - 3:14:33 AM
Long-term archiving on: : Monday, June 7, 2010 - 8:24:02 PM
Hal.pdf
Identifiers
  • HAL Id : inria-00331511, version 1
  • ARXIV : 0810.3079
Collections
Citation
Philippe Robert, Florian Simatos. Occupancy Schemes Associated to Yule Processes. 2008. ⟨inria-00331511⟩
Share
Metrics
Record views
61
Files downloads
144
