Occupancy Schemes Associated to Yule Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
Florian Simatos
  • Fonction : Auteur
  • PersonId : 841874
An occupancy problem with an infinite number of bins and a random probability vector for the locations of the balls is considered. The respective sizes of bins are related to the split times of a Yule process. The asymptotic behavior of the landscape of first empty bins, i.e., the set of corresponding indices represented by point processes, is analyzed and convergences in distribution to mixed Poisson processes are established. Additionally, the influence of the random environment, the random probability vector, is analyzed. It is represented by two main components: an i.i.d.\ sequence and a fixed random variable. Each of these components has a specific impact on the qualitative behavior of the stochastic model. It is shown in particular that for some values of the parameters, some rare events, which are identified, play an important role on average values of the number of empty bins in some regions.
Hal.pdf (267.49 Ko) Télécharger le fichier
inria-00331511 , version 1 (17-10-2008)
  • HAL Id : inria-00331511 , version 1
  • ARXIV : 0810.3079
Philippe Robert, Florian Simatos. Occupancy Schemes Associated to Yule Processes. 2008. ⟨inria-00331511⟩
67 Consultations
154 Téléchargements
