A simple construction of very high order non oscillatory compact schemes on unstructured meshes. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers and Fluids Année : 2009
In \cite{abgrall-roe} have been constructed very high order residual distribution schemes for scalar problems. They were using triangle unstructured meshes. However, the construction was quite involved and was not very flexible. Here, following \cite{abgrall}, we develop a systematic way of constructing very high order non oscillatory schemes for such meshes. Applications to scalar and systems problems are given.
CAF.pdf (1.21 Mo) Télécharger le fichier
inria-00333756 , version 1 (24-10-2008)
Remi Abgrall, Adam Larat, Mario Ricchiuto, C. Tavé. A simple construction of very high order non oscillatory compact schemes on unstructured meshes.. Computers and Fluids, 2009, 38 (7), pp.1314-1323. ⟨10.1016/j.compfluid.2008.01.031⟩. ⟨inria-00333756⟩
143 Consultations
152 Téléchargements
