Proved Development of the Real-Time Properties of the IEEE 1394 Root Contention Protocol with the Event B Method
We present a model of the IEEE 1394 Root Contention Protocol with a proof of Safety. This model has real-time properties which are expressed in the language of the event B method: first-order classical logic and set theory. Verification is done by proof using the event B method and its prover, we also have a way to model-check models. Refinement is used to describe the studied system at different levels of abstraction: first without time to fix the scheduling of events abstracly, and then with more and more time constraints.
Logique en informatique [cs.LO]
