High Security Laboratory - Network Telescope - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2008
While attacks are widespread, network data related to them is rarely available to academies for investigation. In this context, the MADYNES team, which develops research activities on security management, decided to build an infrastructure capable of collecting the necessary data to enable analysis and modeling of malicious systems from a network point of view. This infrastructure is now part of the LORIA High Security Laboratory.
Technical_Report_Network_Telescope.pdf (2.26 Mo) Télécharger le fichier
inria-00337568 , version 1 (07-11-2008)
  • HAL Id : inria-00337568 , version 1
Frédéric Beck, Olivier Festor, Radu State. High Security Laboratory - Network Telescope. [Technical Report] 2008. ⟨inria-00337568⟩
547 Consultations
20195 Téléchargements
